Well, installed my new injectors yesterday. Big thanks to Don for all the work getting us the group purchase. I don't notice much power increase from my existing injectors which were Bosch aftermarket that I mistakenly thought were BD's. Install went well, took 2 hours and fired right up. The biggest difference is the amount of smoke. Far less than before, even up here at 5000 feet. Gene had posted really great install directions that can be found in the archives. Could not believe the rust on my old injectors. A 15mm wrench fits the flats and I gave them a wiggle then yanked them out with a pair of vise grips, no problem. My EGT is pretty close to what it was with the old injectors-500-600 degrees and 5lbs boost at 65mph. I can run it up to 1150degrees in a hurry if I stand on it pulling a grade but seems like EGT backs off and speed will continue to increase if I just back off a bit. There seems to be a sweet spot between too much pedal/ high EGT and getting good power and speed. I have my pump up at 1. 44mm and the Banks stage II setup. I am going to have Wentland Diesel turn my pump to 1. 33 later in December and expect lots more power. We'll see BY the way-Anyone know where I can get this beast on a Dyno to see where I am at?
91. 5 W350 Banks turbo, exhaust, K&N filter, preluber, Optima dual red tops, warn 9K winch and custom bumper, custom springs, Snug Top shell, PW injectors, Pump @1. 44mm, KYB gas adjust shocks, American racing 16X8 alum. wheels.
