My driver's side power window motor quit working several months ago, now that the warmer weather is here, I decieded to replace it. I had the drive motor out last year to replace the clutch, I should have replaced the entire thing then, but I guess I was just too cheap to spring for the extra $100. 00. This time, I removed the motor the easy way. Rather than removing the entire window regulator, and mechanism to get access to the drive motor mount bolts, I cut three 9/16" Dia. access holes on the inner door skin. Now I can slip a 3/8" socket through the access holes to access the mount bolts to the drive motor. Once the door panel is reinstalled, you won't see the access holes.
89 D-250 LE 5 speed 3. 55 Limited slip, Banks Intercooler, 'Ol Blue Specials, K&N, Full Boar Muffler, 3" exhaust, Diesel Dynamics Stage 1 kit, Boost/Pyro. & 16cm2 215K miles.
