Power with Edge EZ?
Help with new 2500
A message from the Wife ;)
I am now testing a Edge EZ in a 99 3500 4X4 with 4. 10 and 275 injectors. What type of power should I see? It is set on level 2 would it be better to set to level 3?
Thanks for your suggestions
The levels on the EZ are not power levels. The EZ puts out about 40hp peak, and 60 to 65hp down in the lower RPM.
The setting is for smoke control. It controls at what boost level the extra fuel is added, cutting down on smoke.
Set it on #3 setting and you will notice more power as the added fuel starts at 2# boost. It will add power on the bottom end :D . Sam
