PowerStroke Difference
No blinkers/ or hazard lights
oil press. sending unit bad
I drove a '99 Power Stroke Auto. a couple of days ago and when you're driving in OD lock up and let off the throttle it doesn't unlock until you touch the brake or drop below speed. My 98. 5 Dodge unlocks EVERY time I let off the throttle -- I HATE THAT--
What's the deal.
lockup difference
bbsher,
There must be a difference in the way the controler for the transmission is set up. You can accomplish the same thing on your Dodge by installing a 'mystery switch'. Only down side is you have to remember to turn it off before the next stop. Instructions for installing the switch are found on the TDR website.
Paul H
That neat feature on the Ford is part of the PCM programming. When you let up on the throttle on the Ford, the TC clutch is still commanded to be on, but the injectors aren't spraying any fuel. On extended coastdowns the PCM will downshift as road speed decreases until road speed gets too low in low gear, then the injectors will be turned on again to light the engine back off for an anticipated stop.
As far as our Dodge Cummins goes, I don't know if any year of our auto trucks ever had this feature. Maybe if DC hears enough demand for it, they might come out with a reflash like the one for extreme cold weather operation.
