Locker Choice
I argued with myself for months over which locker to use in the Dana 70.
I know two people that have run Lockrites in stock CTD trucks with no problems. One has them in the front and the rear and used to wheel his 92 CTD on some pretty tough trails. Both of those guys are running stock power levels.
I have talked to people with tons of 4wd trail experience and the consensus seems to be that although a Lockrite should be fine, they would go with a Detroit because they are bulletproof.
After looking at the incremental cost of the Detroit, it wasn't that much more. After talking to the guy that installs them all the time, he talked me into doing it myself.
I got the Detroit and after using it on the trails and in the mud, I love it!
1. Remove the rear axle and do this on a bench or sawhorses if you haven't been through a Dana 70 yet.
2. Search TDR for Dana 70 rebuild tips
3. My local guy told me I would be OK without a case spreader, a little harder, but workable. It was.
4. Don't forget to oil the bearing before pressing it on the locker and it will go on easier.
5. Due to time constraints (I was running a jeep safari trail the next day) I simply used the same shims in the same positions and reused the ring gear bolts. (I know, I know... ... ) It worked fine and upon later inspection after breakin the tooth pattern looks good.
If I was using my truck in mud or around the farm, I would probably go Lockrite. easier and cheaper
Here there are lots of sand/rock combo trails and the stress of going from no traction to solid grip on sandstone really puts a strain on driveline components. I went with the Detroit for the brute strength.
With the true locker, I do hear the rear tires slip on pavement (or rock) in turns if I apply too much power and don't let the rear unlock. I will experience more rapid tire wear than I would with lim slip.
Ken
