on a practical note,im looking for suggestions for sum more power. lets start with what has been done. fuel pin is turned to deepest spot on the cone(washer removed),power/fuel screw turned in till it stopped and backed 1/2 turn,3200 governor spring, 4. 5 inch exhaust,custom air intake,intercooled,28lbs boost,stock 21cm turbo,stock injectors, egts runnin 1000 after turbo,5sd, 4. 10s.
I tow about 8-10k lbs at elevations from 4000ft-9000ft. Im looking for more practical long sustained power(lot of long grades). im changin to 3. 55 gears. lookin at a 16cm turbo housing and a ole smokey fuel pin.
any other suggestions or adive more than welcome.
oh i got the idle issue fixed, moron me put the top hat and spring for the governor arm on the wrong side of the arm. luckly no harm no foul,thank god!!!Thanks for everybodys help!!!
