I have a Pre and a Post EGT T/C installed. The Post is installed the Banks Brake T/C port. The Banks Brake is a bigger hunk of metal than the stock elbow.
What I notice is the amount of temperature that the turbo pulls out when running with boost. I see Post turbo EGT 200-300F cooler at times at high boost and around 100F at low boost. This pretty much makes sense to me, is it about normal?
Another thing that I notice is the cooldown time between Pre and Post. I am going to say that it takes 3-5 times longer to have the Post EGT drop below 300F than it does the Pre EGT. Typically unloaded, the Pre temperature can already be cooled to 250F and the Post can still be in the mid 300F range. After stopping when pulling a load, the Post temperature can still be in the mid to high 400F range as the Pre temperature goes below 300F. In any case, the Pre temperature drops fairly quickly and Post temperature takes much longer to drop and just creeps down. This normal?
Another thing that I managed to find out is when I did a 5th to 4th down shift running loaded and pulling a pretty good grade. In 5th my EGT was creeping to 1150F so I down shifted. I was traveling 60 MPH at the time and I wanted to see the performance at the same speed. Man-o-Man the EGT's skyrocketed, especially Post as my boost pressure dropped very low. Immediately afterward Pre EGT slammed to 1350F and Post EGT almost matched it. Its like the higher RPM flushed all the heat out of the engine, and there was alot of it. Maybe I barked the turbo, I don't know for sure. For sure, I won't ever try that again.
Thanks in advance;
Jim
Thanks in advance;
Jim
