pre turbo temps
Brake Upgrades
2002 DODGE RAM
I'm just about done installing my pyro and boost gauges. With the probe on the exhaust manifold, what is the max safe temp to allow?
Thanks.
vc
'97 Ram,automatic,3. 54 limited-slip, 4x4,smoothie,BD fuel plate,Prime-Loc.
Do not sustain above 1350F.
I have seen 1600-1700F for very short times and alls well.
By no means am I saying you should push yours past 1350F.
95' 2500 standard trans. 2wd reg cab 125,000 miles.
TST #4 plate kit, 370 Diamond B injectors, Afc spring kit, Gov. spring kit,TST's fuel pressure adapter and 2 guage pillar mount, SPA EGT/Boost guage. Joe D's Sachs clutch is in.
There are lots of posts on this subject, and as I recall, 1350 is generally recognized as a safe "never exceed" temperature for pre-turbo. Some even suggest 1300 as an upper limit. For more back-up info on this, suggest you do a search using key word(s) such as "EGT gauge", "probe", or "temperature. " Good luck.
'97 Ext. Cab 2WD 35K mi,5 Sp Man 4. 10, ISSPRO Pyrometer & Boost
[This message has been edited by gchas (edited 01-01-2001). ]
