Mobil SHC or Mobil 1, Mobil 1 is rated to 450*. 550*before it breaks down. Valvoline makes a good synthetic also.
Search Find an MSDS
Mobil 1 Synthetic Grease Pdf
High performance automotive grease Print View
Product Description Features & Benefits Applications Typical Properties Health & Safety
Product Description
Mobil 1 Synthetic Grease is an NLGI No 2 high-performance grease which combines a synthetic base fluid with a lithium complex soap thickener. The thickener system provides a high dropping point, while additives impart optimum extreme-pressure properties and excellent resistance to water wash, and outstanding protection against rust and corrosion. Mobil 1 Synthetic Grease has excellent structural stability and low-temperature pumpability, making it an outstanding automotive grease.
Features & Benefits
Mobil 1 Synthetic Grease provides the following advantages and benefits:
All-purpose automotive service
Operating range of -37ºC (-35ºF) to +232ºC (+450ºF)
Excellent resistance to rust and corrosion
Outstanding structural stability
Excellent wear protection under heavy loads
Good shock loading protection
Excellent resistance to water wash
Outstanding service life
Applications
Mobil 1 Synthetic Grease meets the requirements of the National Lubricating Grease institute (NLGI) performance classification GC-LB. It is recommended for automotive applications at both high and low temperatures. It is particularly suited for applications such as disc brake wheel bearings, ball and steering joints, and universal joints. It will provide outstanding bearing protection under heavy loads at any highway speed, and where moisture or condensation is a factor.
Back to Top
Typical Properties
Product Number 53201-0
NLGI Grade 2
Soap Type Lithium Complex
Structure Smooth; Slight Tack
Color Red
Penetration, ASTM D 217
Worked x 60 strokes 280
Worked x 10,000 strokes 295
Worked x 100,000 strokes 305
Dropping Point, ºC (ºF) 288 (550)
Viscosity of Oil, ASTM D 445
cSt at 40ºC 220
cSt at 100ºC 23. 8
ISO Viscosity Grade 220
Timken OK Load, ASTM D 2509, lb 45
Four-Ball Wear Test, ASTM D 2266, scar Diam, mm 0. 40
Four-Ball EP, ASTM D 2596, Weld Load, kg 250
Four-Ball EP, Load Wear Index 45
Corrosion Prevention, ASTM D 1743 Pass
Emcor/SKF Water Wash Test, IP 220 (modified) 0. 0
Water Washout, ASTM D 1264, 79ºC (175ºF), wt % 6
Back to Top
Health & Safety
Based on available toxicological information, this product produces no adverse effects on health when properly handled and used. No special precautions are suggested beyond attention to good personal hygiene, including laundering grease-soaked clothing and washing skin-contact areas with soap and water. A Material Safety Data Bulletin is available by calling 1-800-227-0707, Ext. 3265. For additional technical information or to identify the nearest U. S. Mobil supply source, call 1-800-662-4525.
06-2003
Exxon Mobil Corporation
3225 Gallows Road
Fairfax, VA 22037
1-800-Mobil25 (662-4525)
Due to continual product research and development, the information contained herein is subject to change without notification.
Typical Properties may vary slightly. This product data sheet is based on global product data sheets for use with products purchased in the U. S.
© 2001 Exxon Mobil Corporation. All rights reserved.
ExxonMobil Home | Help | Sitemap | Contact Us | Privacy & Legal
Thats what I would use.
Good Luck
Don
