Preferred A/C Temp
How to test leaf springs etc for axle wrap
Fuel Guage diagnostics?
Just a bit of advice to those using the Walmart setup (or any other DIY setup) with the off the shelf cans of R134a: After you connect the refrigerant can to the apparatus, give it a blast or two before you connect it to the low side AC connector on your truck. You don't want whatever volume of air that is in the hose to end up in your system.
