Premium Diesel better for 24 valve?
another torque plate question?
Aluminum Heads
I notice that some fuel stops only have premium diesel. Some say premium is #1 diesel where normal diesel is #2, is that always true? Premium gasoline has a higher octane rating, what is the difference with diesel?
Is kerosene #1 diesel with NO road tax applied?
Is #1 diesel better for the 24 valve motor? Does it make more HP/Torque? Will I get better mileage? Will the injectors stay cleaner and wear less? Will the valve body last longer?
Are there any proven benefits to premium diesel, or is it for yuppie cars?
Thanks,
Joe Greer
2001. 5 QC 2500 White Sport 4x4 LWB ETC 5-Speed Anti-Spin 3. 54 Trailer Tow 241HD SLT+ Tan Leather(Mad Cow Disease) LT265/75R16E
Joe,I am no expert but the cummins is designed to run on #2 diesel. Just make sure it is from a reliable source. I try to find a place that sells a lot of fuel as I heard this is cleaner and don't sit in their tanks collecting bacteria and crud. I carry 100 gallons while full and always put the power service cleaner in which treats 100 gallons. At less than 4. 00 per bottle it takes care of condensation and helps the injectors stay clean. Depends on how often I pull the trailer I usually go at least 1500 miles between fillups. The 4. 00 is pretty cheap I think for every 1500 miles. I am sure someone else will chime in that knows more than me to add to this. Cetane is to diesel as octane is to gas.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
Joe,
Premium Diesel is not #1! Kerosene is not #1. IMO, from best to worst (power and performance) would be.
Premium Diesel
Straight #2
Straight #1
Kerosene
Premium diesel "should" have automotive additives added to straight #2 plus cetane increased to around 50. Straight #2 should be around 42 - 45. Higher cetane is kinda like higher octane. Amoco Premier Diesel and Cenex Roadmaster XL two very good premium diesels here in the Dakotas. Premium should cost 2 - 4 cents more then straight #2.
Number 1 is winter heating fuel oil. No additives, but it will not gell. Check out www.cenex.com for all their info. Note they warranty the use of their fuel.
BTW, I have not used any blend or Straight #1 over the last three winters. Premium #2 and Stanadyne additive.
jjw
ND
The problem with “premium” diesel is that the industry hasn’t yet agreed on a reasonable standard. They have standards all right. They have defined minimum standards for cetane rating, lubricity, detergency, cold weather gel resistance, fuel stability, etc. But right now a fuel only has to exceed the minimum standard in ONE category in order to be called premium. I understand that a new standard for premium diesel is now under discussion. High cetane will give improved cold weather performance, better mileage, smoother running, and possibly a little more power. Enhanced lubricity will extend the life of your injector pump and reduce engine noise. These are the only properties that you can sense in the way your truck runs.
Most premium diesels are just marketing tricks. One exception seems to be Amoco Premium 50, which has both a high cetane rating and good lubricity. There may be a few other premiums that may make your truck seem to run better. But overall, the Cummins is pretty tolerant of poor quality fuel. This is unlike many automotive diesels which were designed to run on the much higher quality diesel that is available in Europe. In North America, it is more cost effective to get reasonably priced fuel at a busy station and use a good fuel additive that enhances many different properties of the fuel.
1999 Quad cab 2500, SB, SLT, 4X4, 5-speed, 3. 54, tow and camper package, Lance 820 camper, Lance cabover stabilizers, Rancho 9000s, Airlift airbags,Reese Titan V hitch, Mag-Hytec differential cover with Amsoil 2000 75W-90 lube, Amsoil air filter
[This message has been edited by Lee Weber (edited 04-10-2001). ]
Cetane is not necessarily like Octane.
Cetane indicates the rate of combustion. The higher the cetane rating, the better the combustion in a combustion engine.
Octane numbers indicate the rate of combustion in a spark engine. HOWEVER, the
higher octane gas will combust at a SLOWER
rate than lower numbered octane gas. This is to prevent pinging and pre-ignition.
I believe about 99% of the population believes the higher octane = higher/faster compbustion which is totally wrong.
Charles
2000 QC 2500 4x4 LWB ETC/DEE Anti-Spin 3. 54 Trailer Tow, Camper Special, DD1's, Practical Solutions boost module, Westin chrome nerf bars, Rhino Liner
My Toy
1969 Toyota Land Cruiser FJ40
350 TBI, Turbo 400, ARB lockers front/rear, 4 wheel power disk brakes, 4. 88 ring/pinion, 3 speed transfer case, full roll cage, Warn 8274, MRT 36 bolt beadlocks with Super Swamper Boggers (16x35x15), Saginaw Power steering, custom bumpers/fenders/nerf bars/skid plate, GM tilt steering column, 6 point roll cage, RCI racing seats with 5 point harness. Conquered Tellico and going to Moab this May. Loves to be pulled behind the Dodge and pass the powerjokes going up hills.
Thanks for all the info guys, looks like permium diesel is not a good deal. No real standard makes it VERY hard to tell what you are buying. The local Marathon station manger was kinda lost, I will keep running Admiral Disel, $1. 359 a gallon here this week.
Thanks
