Preparing for a pretty big trip.
Advice on Selling Price
Speedo Help
So, here's the back of my oem filter housing. Apparently this is where the lift pump is supposed to be.
The second picture shows where the lines terminate on top of the tank.
So, any guesses what's in there?
I'm considering running it low, dropping the tank and having a look.
Looks like an in-tank pump to me.
You’re changing your fuel filter too often. Cat published a white paper a few years back about over servicing fuel filters and how that lowers overall filtration. A dirty filter is more efficient than a new filter. Run them out to the 15K miles they are spec’d for.
Same thing with oil, you’re just wasting money and with the current oil/filter shortage that’s an even worse idea. Even thou I am not a big fan of Blackstone I would still heed their advice, as long as you're getting a TBN report. Then again UOA is really a waste of money on OE, or more frequent, OCI's for this motor. I use to run them but don't bother anymore, it never showed me anything worth the cost and oil related failures just don't happen on these engines.
Definitely carry spares of that Goldenrod filter as they are water absorbing and will stop flow if you get enough water.
Not to derail this thread but is there a water blocking filter option for inline that will work on the gravity type system transfer tanks like I have in my truck? I wouldn't mind putting one in, but do not want to deal with having to re-plumb the whole thing or add a pump.
No need for that as your Truck has an excellent Filter setup right from factory that takes care of business.
You would waste money that way as you exchange your trucks filters anyway every 15K Miles.
There are also better filter options than the Cat, such as the DBF5814, FF5814, or P551313. Either of the 5814's are the best available media for HPCR's.
I know the above mentioned filters are a better option than the CAT 1R-0750 AHE but I thought the CAT 416-1225 UHE was the "cats meow" Its drawback was just the size.
I don’t think it’s any better than the NanoNet stuff from Fleetguard, but it’s been a long time since I’ve researched anything Cat. That’s not a new filter thou.
I quit using cat filters a long time ago as there was better stuff available, better than even their UHE stuff.
I’ve yet to find a filter better than Nano Net, or the Donaldson equivalent.
View attachment 132298 View attachment 132300
You should be able to determine whether you have the in-tank pump and, even more importantly, ascertain that it is actually working (which a mere visual inspection won't tell you) without going through the trouble of dropping the tank. Just turn the key to the run position and listen for it. When the key hits "run" the pump in an '04 will run for 1-2 seconds and shut off. You may, or may not be able to hear that, certainly not over the radio or blower motor, etc. But, if you "bump" the starter without letting the engine actually start, the fuel pump will run for around 25 seconds. That gives you time to get out and put your ear up to the fuel filler opening or directly under the tank. Of course, if you're hearing is like mine, you may wish to have someone younger listen, but if that pump is running, it should be audible. That 25 second run period is also great for priming the fuel system after replacing the fuel filters or after any other fuel mishap.
I do find having "gauges" beneficial even on a stockish truck. For the money and convenience I use the Edge CTS3 with the EGT add on. When I priced out individual gauges it was an easy decision. Plus its a code reader, turbo time etc. You can compare EGT and boost pressure at different RPM's. That shows you where to run it at. Pulling a 30' 5th wheel I find 2200 RPM is cooler than 2000. I have the 4.10 gears, so its not that fast at 2200 to 2300 rpm in top gear. On long pulls up mountain roads run direct drive or 5th gear in a six speed, 2500 rpm or so. High RPM keeps the pistons and turbo happy. 1800 RPM is the minimum pulling on flat ground unless you like 1,000 degrees pre turbo on the EGT reading. I've pulled 18K trailers with my 03, RPM is your friend.
I've always ran an Air Dog with the two filters, still on my original injectors. But, the newer in tank pumps are a lot less noise, wish I had one. Like the others said its highly recommend to add a quality spin on fuel filter if your running the stock canister though. There is one outfit that mounts the additional fuel filter above the injector pump, easy access. I gotta crawl underneath my truck to drain the water separator and change filters, I rather have it under the hood!
I didnt mind reaching under the rear door to drain the airdog.... its a helluva lot easier than draining the primary on the 20'o_O
For the fuel pressure I run a simple pressure LED that lits up bright at 3PSI - which is fine as the CP3 does not need pressure, it need flow - other then it's predecessor VP44 that called explicitly for pressure.
Hey Oxy, Do you mind sharing how you did this setup, a wiring diagram if possible and parts list?
Me?
It's pretty much straight forward and couldn't be easier.
I bought the Kit from BD Diesel and installed it according to their IM.
Only difference was that I used the bottom banjo bolt on the filter bowl instead of the one at the CP3 that isn't accessible on my truck because of the vacuum pump. Positive power I took from the cig lighter.
The switch switches negative, so there is only one thin wire from the switch to the LED in the dash, and one positive wire from the lighter to the LED.
https://us.bddiesel.com/products/5-...dge-1998-2007-24-valve?variant=30073864912960
Me?
Thanks Ozy
Boy oh boy... This is why I love forums. I'm now saving money on gauges, and I'm the proud new owner of a Pac Brake that I am going to install pretty quick here. I also just put one of the BD low fuel pressure led idiot lights in my shopping cart. That really seems like a good plan. I'm also probably going to change my driving habits with the Cummins a little. Most of the big rigs I drove for the past 30+ years wouldn't rev much over 2500 or so, but this little fella definitely is more willing than that. Thanks, everybody.
You know all this, I’ll repeat it anyways:
The CTD will pull down to below peak torque fairly well, but it’s just easier to downshift earlier than with a Class 8 on an upgrade. It’s pretty happy with “high” rpm’s given the higher redline.
Find the published peak TQ rpm and look to bringing it back in right above that number.
From there, shift it across a range a little ways above that in hilly terrain. (Find high & low rpm values).
You’ve got a wider power range to work with and it’s pretty much bulletproof given that the Mama’s boys don’t blow them up.
Trying to run 70-mph on an ascent while towing is where that type gets panicky.
Some of the rpm drops are severe by comparison to an 10-Eaton, so it’s in matching road speed to what you can easily use.
Consistent
upgrade speed is how to play the game. (4th & Direct is how I look at it). If your combined rig is quite heavy and the grade is sharp & long: use rhe gear in which you can still accelerate.
As the Mama’s boys really don’t know how to plan a descent (GOTTA HAVE AN EB!!!) do some practice without use of an EB (bodybuilder guide states only needed where trailer exceeds 10k) as to road speed/gear choice.
TUSON anti-lock trailer disc brakes plus controller worth more than EB as trailer needs to be kept under better control on a descent. (And in rain, etc). Big trucks have had trailer ABS a long time now. You’ll notice the difference especially with winds on a descent.
“Coordinating” the descent with the big trucks is the thing. Having some available rpm’s to accelerate downslope helps with this. (On a three lane I might move to Lane Two from Lane Three to get a big truck past me then move back again). Trailer disc will give you INSTANT momentum change.
Converting the trailer to I-S (Dexter Torflex or MOR/ryde) when adding ABS disc will give you larger/longer pauses in any given gear while pondering choices about what’s coming behind you (wind-handling). 5’ers are pigs with all that sail area (highest likelihood of upset). CAMBER CHANGES are where leaf-sprung 5’ers suck, especially where winds have them heeled over already.
Leaf-spring has next to no suspension (wheel) travel. I-S will help keep those tires where they belong (and easier ride for trailer contents). Downslope plans stay consistent even with changes to conditions. Brake use isn’t an answer when things get too far gone.
The CTD Cruise Control programming is assertive to the point of being aggressive. It’s good at keeping a constant road speed while towing until you’re in hills that slows other traffic (big trucks, or cars not paying attention). Staying in Direct with terrain changes is easiest (OD not a “strong” gear; MPG change not enormous).
The same big truck planning of avoiding EVER being in a pack works even better with an RV in tow. Get‘em around and gone. Pass only on long straightaways and wait to make the pass as the single vehicle. Etc. You know the drill.
Where 55-65/mph is the speed range used (smartest), gear choice is almost not a consideration. (Becomes sorta rare). I stay below the commercial traffic flow and back down to get them gone ASAP they’re passing.
Get a roof-located permanent antenna mount (BREEDLOVE) for the CB and a dual-final radio (GALAXY 86V) to work out a pass with a fast-moving big truck coming up. I let them know when they get out into the passing lane I’ll back it WAY off.
Cancel cruise whenever into passing lane.
Same for within 75-miles of a city center. “Expect” to have to reach for shifter to maximize engine-braking and stay 2-3/mph below the flow once traffic increases.
RV travel has always been 300-miles or 3 o’clock, whichever comes first. 1962 or 2022, been there & done it . . then thru to now. Least stable vehicle on the road. Plan the stops the day before and execute each leg ALONE . Don’t turn it into a work day.
The CB is a wholly new tool should you choose to be of service. The relaxed traveller with complete data of what he’s passed or heard. (West Mountain DSP ClrSp + a Bandpass filter; amateur gear upgrades).
Shift plans don’t consist of much once that rpm range is chosen. (Getting big trucks around and staying backed down till they’re far ahead and truly GONE is the adjustment).
Worst RV’er on the road is the “big” diesel pickemup on a suspension lift with wholly inappropriate tires pulling a toy hauler at or above the posted limit even in crowded traffic. It’s a standard on AM-19 that those kids in the backseat don’t have a father . . baby daddy is at the wheel.
Lights on (always), an extra (and large) convex pair; maximum-spacing in traffic.
IMO, tires need to state BRIDGESTONE or MICHELIN (Duravis or LTX) on sidewall. BILSTEIN or KONI shocks. Rear anti-roll bar if not present and upgrade front by smallest size change.
Zero
steering play (whatever it takes). Required counter-steering is the thing to eliminate.
Even with a brand-new trailer: 4-whl align and bearing service.
Consider a BIG high-mount third brake light that can be seen FAR abaft. (With a motorcycle brake light flasher?).
Conspicuity Tape on rear (maybe sides) with best 3M as per FMVSS.
Get CAT Scale numbers: full fresh water & propane plus gear permanently aboard (). Truck with all persons and gear carried for a trip (or substitutes). TARE and later as usual trip weights. (And truck separately)
Do a sliding tandem weigh (scalemaster must help get tandems onto separate pads). Per axle discrepancies MAY NOT be a problem, but you’ll want to know. (Always travel full fresh water to keep COG at lowest point).
Data also should include recording engine hours vs odometer (average mph), not just fuel burn (FUELLY app makes easy).
Diagnosing problems can’t work without baseline numbers. Towing just makes that harder than before. Get the right start.
A CTD with the mans’ trans is a marriage made in heaven. You’ll love it.
