I have begun the installation of the AirDog on my truck. I ordered the High Performance version. I was called ahead of the shipping, and told that they were no longer going to be selling the basic version, and that all were going to be the high performance version and would be sold at the lower price. I was only charged the lower price, but all labeling and numbers on the product received indicate that I did not get the high performance version as ordered.
I had thought that it was something that could have been accomplished relatively easily. I think that the initial quality is there. I like the heaviness of the brackets and the components. So far, I just have the brackets mounted, and the unit mounted to the brackets. I have not run the new fuel lines or the harness, so I can not offer any input to that. Here are my thoughts on the product thus far. Keep in mind, I am a moderately novice mechanic, so bear with me. The sketches in the instructios are a bit hard to follow at times.
1. It took some test fitting of the components to figure out the orientation of everything. Once that was figured out, the following problems were encountered.
2. The bracket that mounts to the bed mount bolt has a flange on it that was too wide to fit within the webbing of the bed brace, so it took some time with a grinder to get it to fit, and then had to be re-painted. Perhaps of no significance, but one I think needs mentioning, is that a new bed mount bolt should be provided, as you are decreasing the threads by the thickness of the bracket. I am sure it will still be okay.
3. The bracket should have been conformed to not only fit inside the web, but also to contour to then fit flush with the bed channel. Stainless steel washers were used to space down so that the bracket fit level.
4. The backing plate did not fit well within the bed channel, as it was very difficult to line up the holes for the bolts. I think it was hitting the area where the bed mount bolt comes down through the bed.
5. The stainless steel fasteners that mount the airdog unit to the bracket were not long enough. There was only one or two threads showing when the fasteners were inserted, not even allowing the nuts to be turned more than a ¼ turn. So a search had to be done at a hardware store for adequate replacement fasteners.
6. In a system that costs 700 dollars, I think that if a fuel resistant thread sealer tape is required, that it could have been included. I had a heck of a time even trying to find it, and am sure it could have been bought in bulk and thrown in the kit. Seems stupid to get to the point where you need sealer to install the fittings, and then have to run to a store to get it, without your vehicle to get there. And also, are we to believe that the hoses will stay on the barbed fittings without hose clamps? Shouldn't clamps be included in the kit as well. I am struggling with the concept of a kit that is of this caliber and price, with this lack of attention to the details and the little things that cost next to nothing, but are extremely vital.
And this was what I have run into in the installation thus far. Perhaps for people who own or have access to a shop, these are insignificant issues. But for someone trying to install this in a garage with basic tools, some of these are quite significant. There isn't any mention of having to lift the bed, or drop the tank to install the fuel pickup hose, but I am trying to figure out how to accomplish that. I will post more later when the fuel lines and harness are installed. I am not bashing the product at all. In fact, I think it will be a very good product once it is installed, if it performs as good as it is supposed to. Just wanted to bring to light some of the things I see as a non-expert when it comes to installation.
--Craig
