... I've recently installed a rail pressure gague that I received from 'DieselPower' via the group buy... Thanks Wade... .
I have a predator box on my '05... I was suprized to see just how quickly I can max out the rail pressure gague (26500psi) and suck the fuel pressure gague down near zero with the box set on 100hp... . Once I roll on the gas, it doesn't matter if I let up or not, the rail pressure stays maxed until I stop accelerating and begin to coast a bit...
I have since removed the box... . I need to find out just how bad this is for my truck before I put it back on... . I have a dozens of question but here is a short list... .
How much pressure is too much?
I only turn the box on to mess around... never tow or cruise with it, is occacional romps ok or is high pressure damaging every time?
When the box is installed but turned off I get higher boost and rail pressure levels than if I unplug/remove the box, so it must still be doing something, right? Is the box not really ever 'off' ?
I understand that there is a relief valve that may open if pressure is too high. Where is it and can I tell if it has ever opened?
I appreciate any advice/input...
Thanks in advance
Toshiro
Thanks in advance
Toshiro
