Primeloc Restriction Guage is on!!
ATF IV
Battery Covers
Picked up (and installed -what an excruciating wait!!) my new filter restriction guage from the Cummins place today (Las Vegas Cummins Intermountain on Losee Road) ... Cool-looking little unit. . 3 main pieces, 2 of which are adapter plates, and one is the indicator, a few little o-rings and some REAL SMALL #ad
allen bolts--- I'm not a FAT-finger kinda guy, but the 15-minute install could have been 5 with a little design improvement and some larger allens---- enough ******* and moaning, it's on fer cryin' out loud!
The indicator attaches right onto the front of the filter-head, (designed for the newer "black-butterfly" filter-head, not the older silvery rectangle--will need adapter of some type)---simple little red/green plastic rod behind a clear window. . hidden coil spring in one end. . small amt of pressure comes from both "clean" and "dirty" side of filter--when the "dirty" pressure is 5psi higher than the "clean" side, the red is all that shows (shame on you! #ad
)... all green-minimal restriction #ad
half-n-half abt 2. 5--HVAC should change filters there!! #ad
There's probably a politically correct pink/purple version for California, so as not to discriminate against red-green colorblind people, or those who have a pink/purple "preference #ad
" #ad
The Prime-Loc fuel pressure differential gauge is a trick (and useful) little gauge. I've had my Prime-Loc fuel filter relocation kit and fuel restriction gauge installed for over a year and a half now. Heck, I even had to give Cummins NW the gauge part number (from the TDRelease article) at the time I ordered all the other Prime-Loc components.
Rich, the gauge is easier installed onto the Prime-Loc filter mounting base prior to mounting the assembly to the engine although, I would take adequate protective measures for the face of the gauge.
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X spray in liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Reese Titan V hitch, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, '00 Sport grille, '00 Sport headlights with PIAA Super White 9007/9004 bulbs, 4-2-7+4 Brite-Box, PIAA Dual Sport 900 auxiliary lights, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, BLACK '00 valve cover, Banks Stinger 4" dia. stainless steel exhaust system, BD LV V-10/Cummins hybrid TC and valve body, BD modified transmission front pump and PressureLoc, Air Bulldog induction hood (with NACA ducts), plus many other trick modifications
I am really considering getting one of these units when I get my '01. Is it really worth it? Does it make filter changing that much easier? How easy is it to install?
howdy,Jon--my Primeloc's been on since November (Happy b'day 2 me/Happy b'day 2 me!)
--didn't even know about such a guage 'til I saw one (earlier design -round little dial) on another guy's truck---this's a rectangular spring-loaded bar behind a window. . same purpose,different look... . for the ease of filter changes, on a 12-valve they are a Godsend-- the overvalved have a better location to begin with, but I haven't had to deal with that---others' double-dozen opinions? let this future overvalved guy know whether Primeloc is "investment" or "just pretty decoration"---for us "primitives" there's pretty much no debate
98 12-valve qc2500(made in Canada,eh) 4x4/kill-switch, K&N,silencer ring hanging in garage,600amp quick-connect jumper cables, 4"straight-thru 5" chrome slant-cut outlet angled out fwd of rear wheel,PrimeLoc,Warn Front receiver,100Watt offroad lights, 19. 5"Ricksons w/Goodyear Unisteel 159 tires, camper shell, Westin step-rail/nerf bars, diamond-plate rail caps, bedliner,12-V weatherproof outlet hidden inside rear 1/4-panel, B&M remote trans fluid filter on framerail near t-case,whole BD setup(except torque converter) (valvebody,Torqloc,injectors,#5plate,Isspro trans,exhaust temps,and boostguage,exh. brake(60lb)))aux backup lites, ported airbox, 3 snide bumperstickers, Tazmanian Devil mudflaps and floormats--"%$*#)%$^#"-(translation:"TAZ LIKE DIESEL")
You are right Rich! The Prime-Loc on a 12v is a necessity, only a luxury on a 24v. That said, I prefer replacing the entire filter (cartridge) assembly used by the Prime-Loc as opposed to replacing the OE filter element and all the little O-rings. In addition, the two differents filters cost just about the same price. When changing fuel filters it's extremely unlikely you will introduce (unfiltered) foreign material into your fuel system with the Prime-Loc setup, especially when you have to do it in the dark along the side of the road in the middle of the night.
