A few months back I wen through the replacement of a VP44 on my 2001. I started with the FASS pump, then a new VP44, etc. Once the pump was in, the idle was a little rough and I had dead spots at 1500-1700 rpm and again at ~3000rpm. Took the pump out, had it tested and it cleared. I then went and replaced the injectors since the truck was near 180,000 miles. In the process, I developed a priming issue, where the truck will need the starter bumped in order to start if it has been sitting for a while.
I have checked and rechecked every fuel fitting I can think of and it still loses prime. I even went back to the original fuel pump thinking that maybe the FASS set-up had a bad check valve. I haven't conqured this issue. Any suggestions.
BTW, the misses seemed to clear-up with a replaced IAT sensor. I got this thought when I realized that the truck idled very well until warmed-up.
Thank you!
Thank you!
