PROBLEM SOLVED---Turn Signals, Brake Lites and Trailer Brakes Failed
Anyone from Iowa have a H&H trailer?
5th wheel hitch questions
PROBLEM SOLVED, SEE BELOW... .....
Original message:
Hooked up my trailer today and as I was driving away, I checked the operation of my trailer brakes before getting on to freeway. For some reason they would not grab. I tried adjusting the Tekonsha controller and could not get a fix, amber light indication. I did not have the adjustment instructions with me, so I took it home slow, 20 miles. Turn signals worked before leaving. Did not check brake lights, leg is not long enough.
Half way home I came to a stop light, applying the brakes and turn signals, the turn signal started to blink really fast then shut off. I pulled over checked the obvious connections and all seemed fine. I disconnected the trailer hook-up to the truck and still no turn signal nor brake lights. All other electrical works fine, Running lights on trailer, head lights, parking lights, lighter, dome light, radio, etc. . all OK. Checked all fuses in cab and under hood and they are fine as well.
Wiring harness? Or has someone experienced this same problem? I just recently had this setup installed [11/09/01] and am hoping that the splicing into my wire harness was done correctly. We just had our first rains out here and I'm wondering how long I have gone without brake lights?
Any help would be apprecaited. I'll be under the truck tomorrow.
Doug M.
PROBLEM SOLVED:
After looking a little closer, the #4 Slot [Hazard] in the under hood fuse box showed a 20 amp fuse blown. Replaced fuse with a 20 amp and all is fine. I spoke with my mechanic, Dodge Boy, and he explained that the local city purchased the same truck as mine and with the additional yellow flashing lights installed for the city truck, they kept blowing the same fuse. He upgraded to 40 amp rating to their fuse box and haven't had a problem since.
Moral of the story, carry extra fuses, flash-lite and a magnfying glass. These new rectangular fuses that are being used are very hard to see a burnt element. Certainly with these ole' eyes.
Hopefully not to be continued. .
Doug M. :cool:
Had the same thing happen to me when I accidently hooked my trailer battery up wrong. When I hooked up the trailer, it blew the fuse.
Brake Light Failure
When returning to California this Spring we did our usual pre departure check of our trailer lights and found we had lost our brake lights, turn signals and running lights. The truck turn signals also did not work. The local Dodge dealer replaced our turn signal switch and the problem, was solved.
