Fellows, I checked my TAG when I changed the oil and filter this morning - everything was fine. However, when I was reinstalling the inlet air boot on the turbo, I ran into a situation that might offer an explanation to the TAG turning sideways.
If the honeycomb section of the TAG isn't perfectly aligned with the air inlet of the turbocharger (it actually slides inside the turbo), it will bind and "kick" one side of the TAG's mounting ring out of the groove in the boot. It happened to me this morning - something didn't feel right, so I pulled the boot back off only to find one side of the TAG out of the groove and cocked.
The only way that I could install the boot and know that the TAG was in place was to remove the BHAF, reach in with my right arm through the air inlet boot to maneuver the TAG with my right hand while guiding the boot onto the turbo with my left hand. If I do this correctly, the honeycomb section of the TAG is engaged into the turbo inlet with the TAG flange almost in contact with the front face of the turbo's compressor housing snout when everything is in the "finish" position. If the honeycomb is engaged in the turbo inlet and the TAG's flange is in the inlet boot groove, there's no way the TAG can cock in the intake boot. It would physically have to change position to do so - it has to disengage the honeycomb from the turbo in order to cock. Could a turbo surge do that? Dunno - that's another matter. My point is, if you don't physically guide the TAG into place as I described above, there's every chance that it was cocked during installation.
Rusty
Rusty
