I am running a Tekonsha Prodigy controller, whichever one was current in 2006. It is connected with the pigtail add-on that came with my truck. It's worked perfectly since the day I bought it. But on my last out of town tow, about 3/4 of the way to the destination I noticed that I was getting an intermittent overload code (OL), which sometimes turned into a short code (SH), and occasionally the not connected code (NC). Sometimes applying the brake lightly would get things back in order, but the problem persisted intermittently until I dropped the trailer off a few days later. I wasn't too worried about the return trip with the trailer unloaded, but it's 12,000lbs on the outbound side so that's a real concern.
After finishing the trip the friend who owns the trailer and I checked all the wires and connections. We found a few spots where it looked like the insulation was a bit worn, so we taped those up, but the problem persisted. Next we started to check the amperage to the brake magnets. Left rear magnet (dual axle trailer) read low, and the right rear magnet read el zippo. Even though the brake pads were still in decent shape we figured it was a good time to change it all at once, rather than just change the magnets. Magnet cost was just under $30, while the complete assembly was just under $50. New magnets, new pads, new springs. No question on which route to go here.
But this is where the problem starts. We got the new brake assemblies on correctly, i.e. left and right. The magnets are at the bottom, attached to the swing arm which pulls to the back of the trailer when rolling forward. The brake pad on the front of the assembly is pushed out. We got all four on, and adjusted them so that when the wheel was on it would spin about one revolution when the trailer was jacked up and no brakes were applied. We figured that was about the right amount of friction. But when we road tested the trailer the brakes barely slowed the truck down with the Prodigy set on 5, and using the lever on the brake controller. It did better at 12, but still didn't lock the wheels up like we expected and didn't really hold the truck still while stopped in drive and using the brake controller lever. When the wheels were jacked up off the ground the brake controller level would stop them very quickly, but we could force the wheels to rotate using a considerable amount of push. So it sounds like a low current problem at this point.
We then adjusted the brakes so that the wheel only spun about half a turn, and got the same results in the road test (which was actually on gravel and grass). What else could be the problem? The only thing left I see in the equation is the Prodigy brake controller, but I don't know anyone who has had a brake controller fail. We had to stop because it was getting dark, but we adjusted the brakes back to about a one-spin tension on the springs, and my friend who owns the trailer is going to hook it up to his truck tomorrow and see how it works with his Prodigy, which is an older model. Is there something we missed when replacing and adjusting the brakes, or is it most likely going to be my Prodigy failing. I'll also add that I moved a couple of years ago and the driveway at my new house is sloped downward from the road. Because i don't like to back out of the driveway I back into it when i return home. When I come to a stop I notice that the "_ _" code shows up on the Prodigy (no trailer connected). It also comes on when I leave the driveway, but goes off right when I get on the road. The brake controller is mounted parallel with the truck frame, so I've just chalked the code up to the angle of the truck. On level ground the brake controller is level.
Anyone have some info on what is going on here? Thanks in advance.
