Need some help here. Bought CATZ 4300K HID 9007 headlight conversion kit. The whole thing plugs together, couple of grounds and a positive wired to the battery. The only other way it wires to the truck is it has a 9007 style receptacle that the OEM headlamp socket plugs into. So I plugged the passenger headlight harness into, to finish up and it doesn't work. The HID kit just flickers. The kit uses the OEM headlamp harness to turn on the HID, and also to switch high and low beams.
I took everything out, and put the stock bulbs back in so I'd have lights, well now the passenger side (side I drew current from for the HID kit) low beam doesn't work, but the high beam does. The kit suggested to replace the OEM fuse with a higher rated 15 A fuse. Problem, our trucks lights plug right into an Integrated Power Module.
So, am I going to have to use the OEM headlamp socket to switch a couple of relays which will feed the HID's??
Any suggestions would be great.
