Ok guys, I am not a newbie to CB's been around them for a long time, but I am fairly new to linears. I have a Galaxy 99 with a Palomar 600 behind it. I have had them matched by a trained person. However when I intalled them I am having a serious problem with the linear. I turned the power down on the Galaxy (they have an adjustable power knob on the front for those of you not familiar with them) then turn on the linear. When I key up I have nothing but serious feedback in the ext. speaker (mounted under glove box. (radio's are mounted under center console)). On top of the feed back my electrical system for the truck (windsheild wipers, and lights) goes haywire while keyed up. Now when I turn the linear off and just use the galaxy alone it seems to work fine.
Now for diagnosis info. I do have a aftermarket stereo with a 350 watt amp pushing 2 10" subs in a reg. cab. (I am smart enough to turn entire stereo off before attempting to key up at all. ) The way I have everything wired is a single 6 guage (with a 100 amp fuse mounted near battery on fender) coming off the battery into the cab where I have it run into an alternate fuse block to run the cb, linear, and amp. then all three are grounded to the same spot.
I am not sure what I have done wrong in the instalation, or if something is wrong with the linear itself. If it is determined that something is wrong with it interally, I need to find a good radio man within a few hours of KC, so let me know if any of someone.
TIA
Russell
TIA
Russell
