Problems with innercooler hose off turbo
ULSD Info (ultra-low sulfur diesel fuel)
BD speed eliminator confusing air conditioner
Has any one found a better replacement hose for the flexible one right off the turbo? I run a TSTPowermax CR with a 4" exhaust for proformance and I am have troble keeping this hose together. I run the TST on the recommended 4 settings under normal driving and back it down to 2's when towing. My bost gauge never gets above 42 even under hard acceleration. The first hose lasted quite along time, around 60k. Now the hose I just got from the dealer 4k ago is showing signs of expansion. Currently BD only sells the other 3 hoses as an upgrade. Need some help. What are you higher HP guys doing?
Thanks,
Aaron
Could you tell me what size you had to get for the o3. I would like to replace mine have blown it off a couple of times never close to home so had to fix on road. Never taken time to measure diameter.
stock = 2. 75" diameter
If you buy the 4 ply hoses, you might have to buy new clamps since the stock ones might be a hair to small.
