While all ready up to #3, this nice weather is allowing me to catch up with a few projects I started but didn't think I would get installed till spring. That will most likely be the case for most, maybe even this one, but I did manage to complete 75% of the work this last week.
The project was to install an additional transmission cooler to the truck. I just recently installed a new ATS transmission and I wanted to protect it from over heating. Haven't had any reasons to believe it would over heat, but I would like to err on the side of conservativeness and be prepared. Before the switch to ATS, the trany would get hot (190-210) during stop and go traffic and long backing situations. The normal highway temps run in the 140-150 range.
I picked the B&M Hy Tech auxiliary oil cooler, it looked very well made and came complete with electric fan and thermo switch, also the fittings were 1/2" NPT not barbed. Looking under the truck, I wanted a place fairly close to the transmission that also offered some protection from road Debra and did not interfere with future mods or repairers. Another consideration was the air flow, it could not be pressed up tight to the floor board or frame rail. It does have it's own fan, but there still needs to be adequate ventilation. Of all the spots I tried, the best location seemed to be behind the transfer case. Their it is protected by the transfer case and skid plate, yet I could still get the slip stream on air I wanted. By attaching the cooler to the skid plate, I could easily fab a mount in the shop and not under the truck, plus everything could be removed easily if needed. I used some 3/4" square tubbing to make the frame work and secured it to the skid plate with 3-3/8" bolts. The cooler get secured to the frame work with 4-1/4" bolts and is also protected by some 1/2-16 flattened expanded metal.
This is the bottom view of the transfer case skid plate (black) and the new oil cooler mount in blue
Close up of the oil cooler mounted to the mount and skid plate. The design is strong yet light weight, and offer the cooler a secure and protected mounting place.
This sort of gives you a feel for what it will look like when mounted to the truck. There is a rake to the mount which allows it is position itself away from the back of the transfer case and into the slip stream. The mount itself is no lower then the transfer case skid plate, which keeps it up and out of harms way.
Like I said earlier, I have know ideal when I will get this mounted to the truck, it might be awhile. Most of the work is done, I only have to mount the plate, splice into the return oil line and run a 12V wire to operate the fan.
