Well, there was only 5 of us there, and my truck was the only one to get the LP move done. Earth Roamer was there and is evidently going to do a write up on it - he did take lots of pictures, some at a bad time to be popping a flash. He did not stick around until the finish, kind of took a while. Spent an hour fighting with a dead LP that I had sitting around, and I reversed the wires on the pigtail when I made the extension. After I pulled the new one from the engine bracket, we were done in 20 minutes. The move is REAL easy. If I had to go out and do it again right now, and I had all the parts, I could probably do it in an hour. I will do a write up on it tonight and post tomorrow sometime, kind of a step by step thing.
Results - Idle is 15. 75 psi and after two hard runs with the EZ on level 3, I could not pull the pressure below 12 psi. Pleas note that I still have the OEM line from the filter to the VP (we did not get any "T's" so I could plumb in my FP gauge. I am going to try to drill and tap the one 90* elbow in the entire system tomorrow. Otherwise I have 2. 5" of 3/8 hose from the pickup then 1/2" RED GARDEN HOSE :-laf from there to the fuel filter. The worst part is disconnecting the fuel line from the pick up at the top of the tank. Came off easy enough (I know how they work) just real uncomfortable trying to get to it.
Sticks
