This question concerns a 2017 Ram 2500 68RFE auto Trans, 3,42 Rear, 4wheel drive LT285/60R20E DWL On/Off Road Tires and the Offroad Package.
The trailer is a 2 axle boat trailer with 4 wheel electric over hydraulic DISC brakes---total weight approx 13,000lb.
Normal procedure is to level the trailer and measure from tongue to the ground. Adjust the trailer hitch so the height of the ball matches the height of the tongue. The result ---BEFORE tongue weight is added, should be that the trailer is level with the weight of the load distributed evenly to both axles(2 axle trailer)---Once the tibgue weight is added the rear end drops down and this is finally adjusted by setting the weight distribution springs to bring the rig level.
Now---for some reason the documentation that came with my new trailer----after it explains all of the above---specifically states "For Owners of Ram Vehicles, it is recommended to set the height of the tongue TWO INCHES HIGHER and adjust from there.
I'm confused. Can anyone elaborate as to why this recommendation?
Eddie
Eddie
