After reading several of the posts about changing the PS fluid by removing as much as possible using a turkey baster, replacing with new fluid and repeating the process, I decided to give it a try. I tried the turkey baster a few times and then came up with the idea to try the oil change pump for my boat that I had sitting on the shelf. This pump runs on 12V and designed to suck the oil up out of the dipstick tube for changing the oil in a boat. (Pulling the oil plug and running use oil through the bilge makes a real mess!). Anyway, the pump worked great
for pulling as much PS fluid out of the PS pump as possible. The truck has 40K miles on it and the PS fluid was a very dark brown. Does anyone know what type of fluid is put in at the factory (ATF-4?)? Anyway, I have cycled through the process twice and replaced a quart of fluid (Valvoline Semi-Synthetic). I think I'll drive the truck for the week and then change out more PS fluid next weekend. If it wasn't for the TDR, I would have never thought about changing, and how to do it, the PS fluid. Thanks to everyone.
