The truck is a 98. 5 4x4. The power steering pump had a leak, as did the steer gear. I replaced the pump,and rebuilt the vacuum pump all was well steering ok and brakes worked as usual. A few days later the valve in the ps pump stuck and i lost power for brakes and steering. I unstuck the valve and did the upgrade on the valve in the pump. A couple weeks later i replaced the steer gear with a pss gear, blead per chip's instructions and it was working fine till today, the valve stuck again and i lost brakes (hard as a rock) but steering worked when the truck was rolling. I got it home and unstuck the valve again,( replaced the valve with one from junk yard. )
Now steering is great but my brakes suck big time. I don't have any bubbles in the ps fluid so i don't think it is an air issue.
How does the booster work? Does it bypass to the steer gear and overflow to the ps pump on the center return, until you step on the brakes, then activate the master cylinder with pressure for assist, while still powering the steergear?
Is there any test for the booster other then replacing it? Could the valve sticking have damaged the booster?
Any thoughts appreciated.
Dirk
Dirk
