EZeis
Hello,
I have a 2018 Ram 3500 with factory goose/5th wheel package. I bought a B&W 5th wheel to fit the Ram pucks. Either the B&W base is tweaked or there is an issue with the pucks. The hitch base doesn't touch the right front puck. This causes it and its opposite to teeter back and forth. I called etrailer and the tech said the pucks on the truck need adjusted. I looked but there is no slots in the puck mounting bolts. I put the hitch base on two different concrete pads is different locations and the base teeters a little bit but on different latches than in the truck. But doesn't teeter near as bad as in the truck. So I don't know if I have a truck puck issue or a hitch base issue. The right front puck is visually lower then the other 3 from the bed surface.
Anyone have this issue before? I tried to upload a video but even at 11.1mb it's too large.
Thanks,
Earl
Thanks,
Earl
