Pulls right
creaking noise from body mounts
Are good alignment and straight braking a paradox ?
I have a '99 3500 2x4 Dually that constantly pulls slightly to the right. Not enough to be dangerous but enough to be annoying. My dealer has aligned the front end and I'm not getting any unusual tire wear or harder pulling when the brakes are applied. Has anyone had a similar experience?
Kaiweb
What did the dealer have to say after your truck was aligned? Did they provide you with a print-out of the results?,and if so could you show us. Another possibilty of the pull is simply in the tires. Try rotating the front tires side to side,if it now goes straight the pull is the tires,but if it still goes to the right chances are its the alighnment. Another possibility is the steering box. Does the steering wheel jerk slightly to the right on start-up? If so the proportion valve needs adjusting.
