Ok, here goes.....
1980 W200 4x4 w/90 Cummins Non I/C, 5spd, 3. 54 dana 60's
I will probably need the assistance of a repupatable shop to replace my injection pump. So, here is the story... We marked diaphram, and indexed it like the others that were done, and the fuel pin did not want to come out, so the starwheel was turned 1 full turn CW, and diaphram about 120 degrees. Anyhow, prior to this the max boost was 12, and the truck was a turtle, but did everything you could ask of it, and after was 7psi. Something isn't right, so the top cover came off again, and re-indexed the diaphram back. After that, it was lucky to hit 6psi, and wanted to die if trying to take off in 2nd. So anyways, I had a 35 mile drive to get home, so I make it back home and look more into it... . I was finally able to pull the pin/diaphram, and it looked like it had calcium build-up on it. It took a little while to get it cleaned up, but it is clean now, but I have another problem, the lever that rides against it stuck, and from what I think is the same calcium like substance that was on the fuel pin. Anyhow I have it soaking with some penetrationg oil on it, in hopes that it will free up. Has anyone else ran into this, and what did you have to have done? If the pump has to be done, it would be the perfect time to have the 3200 spring put in... .
Sam
Sam
