well ,just got the the pump balanced injectors flow tested and balanced ,3k springs in the pump 16* timing and 60# valve springs ,, the tech said the truck will idle high because it will stall out ... . idles at 1000 rpm's now anything less it will stall as soon as i put it in gear ... is this true or does the pump need more adjustment... .....
thanks for any info
tony
thanks for any info
tony
