If it was from a Cummins engine, it should fit. How well it will work is another story. You could always use the body to make a custom pump.
EDIT- just looked at the numbers, and I believe it indicates a 10mm plunger & rotor. There is a breakdown floating around the net (maybe 1stGen?) of what numbers mean and the codes thereof.
Daniel
