Pump Identification
WH1C Wastegate Actuator and Bracket
engine health
I have a line on a pump. The numbers are as follows.
VE R 209-2
147-0465-21
844-09681
VR 0 460 406 060.
I was told its for a generator. No KSB and different gov spring. Anybody got any ideas if it will fit my 89. .
If it was from a Cummins engine, it should fit. How well it will work is another story. You could always use the body to make a custom pump.
EDIT- just looked at the numbers, and I believe it indicates a 10mm plunger & rotor. There is a breakdown floating around the net (maybe 1stGen?) of what numbers mean and the codes thereof.
Daniel
