Got my truck back with the rebuilt pump yesterday. Runs GREAT but I suspect there is some power still available. The cost ended up being what I could have ordered a new pump for. I took a chance that perhaps the only problem would be a bad O-ring but ended up with a full rebuild.
I have a question for anyone with a 1st gen whether it is stock or not. Who has had their truck on a Dyno and what were the results? What kind of HP and Torque did you get. The shop that did the pump changout put the pump on straight up and then put the truck on the dyno. Did a performance tune using the dyno as a tool. Ended up with 180 HP and 430 ft/lbs at the rear wheel. He told me this would be about 225HP and 550 ft/lbs at the motor.
Still have not changed the turbo housing to a 16cm but was hoping for a bit more power with the PW injectors and a slightly tweaked pump. Do the above numbers sound about right? How much additional power can be realized by changing the housing?
I told him before he started that I didn't want a lot of smoke and that is probably why he was conservative.
Wonder how long the tires will last? Hmmmmm. .
Stan
93 2WD extended cab, Banks Power Pack, K&N Air Filter, PW Injectors,Auto w/4. 10 rear with limited slip, US Gear Exhaust Brake, 31/2" Exhaust, 5K air bags, Boost/Pyro/Tach Gauges, Green/Silver, new 40-20-40 bucket seats, 149K
[This message has been edited by paccool (edited 02-18-2001). ]
[This message has been edited by paccool (edited 02-19-2001). ]
Stan
