This is a question for the P7100 pump masters out there, Piers, Donnelly, etc. I have a 97 5spd. 215hp engine that I’m going to install an 180hp pump on, what I need to know is should I use the lift specs. for the 180hp pump or the 215hp pump. From what I have been able to glean from this site the pumps have different duration/lift on the pump camshafts. So I believe to time the engine correctly with the 180hp pump I should use lift specs. for the 180hp pump, is this correct or not. If not, maybe someone could enlighten me on the correct procedure and explain why my thinking is in error.
Before anyone chastises :-{} me for changing pumps, this 97 5spd is a tow only vehicle and the 180hp pump with a #4 plate and DDII’s will give me all the power I need for towing. Also don’t ask if I’m selling the pump, I’m not; It’s for the 2001 engine I have for future use.
