Pump timing
ATTENTION Fire Burnt Amber Dodge
VA plug-n-play
Well I finally found a shop in my area that does pump timing and gave them a call and talked to the owner he sounder VERY knowledgable and very easy to talk to, he said they set the timing to 15*-16* depending on who drives the truck the most, me #ad
,so he would probably go to 16*. I will have to make an appointment with him in the very near future to get this done and will let you all know how much it was off and the results. I am hoping the results will be as noticeable as when I put the #11 plate in.
Paul
'96 2500 ext. cab, LB, 4x4, 5 speed, 3. 54, TST 280 cam plate, AFC spring kit ,pyro and boost gauges mounted on A-Pillar, tinted windows, 16x8 Eagle alloys series 1219, 285/75R16 Durango A/T's, stainless steel rocker panels and alluminum stirrup steps
14. 5°seems to be the best general timing number. You will get more power with 16°,but it may make the engine harder to start.
More hp: yup. Better mileage: uh huh. Higher egt's: ABSOLUTELY. Be sure you know where you're going with this.
I've never heard of a pump shop reccomending you advance it to 16 degrees. Every reccomendation I've ever heard says keep it in the 14's.
No one out there knows more about this than Ted Jannetty. Why not e-mail or give him a call and discuss it with him.
'94 SLT 2WD, 5 Spd. , TST #6(250/635), 215 HP Injectors, Calibrated Pump, 14. 5 cm2 Turbo, ATS Exhaust Manifold, 3. 54, all Synthetics, By-Pass Filtration, EGT & Boost Gauges, Psychotty Air System, 4 " exhaust, BD Exhaust Brake, Horton Fan, Prime-Loc, Cummins Chrome Kit, Homeless Cat, Air Lifts, Rancho RS9000's, PIAA's, 255x85Rx16's and copious amounts of 12v Pride.
Joe D. Advised me that if a governer spring kit is in your future to advance the timing more. He adjusted mine to 16 Deg. As far as starting goes it starts better and the EGT seem alittle lower not higher. My milage is up about 3/4 miles to the gallon.
I would also talk to Joe he's the man on the 12 valves now that Piers has gone over to the dark side... . LOL
EAT'M UP
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, & Psychotty Air System, TST #11, 370 HP injectors, timing at 16 deg. , 16CM2 housing, AFC spring kit, Geno's Exhaust Blanket, TST EGT gauge & 0-60 boost gauge in A Pillar, Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, Rad fan removed, AmsOil Through out, Geno's trans filter kit, AmsOil Bypass system, Lund Winter front, Leer Cab Level Shell Driftwood , 255/85R16, Dyno'd 342 HP pre injectors & turbo housing *NRA/USPSA member and proud of it*
Yes I did also talk to Joe D. and he suggested 15-15. 5 also I had mentioned those numbers to this shop and he said that they go on the lower side, 15* if you have differant people driving the truck who do not know how to control themselves and the truck but seeing as how I was mainly the only driver, that he could put it to 16* or were ever I wanted it. So everybody speak up and let me know what you have put yours too and the pro's and con's of it.
Paul
Mine is at 16 and I don't notice any adverse effects at all EGT maybe slighty lower power hard to tell by seat of the pants.
I talked with a gentelman today at a performance diesel shop, who recommended 16. 5 with 300 injectors and delivery valves.
Is he out to lunch? He seemed very knowledgeable. He did make mention of the EGT's likely being a concern with that setup.
Comments?
Comments?
I talked to a vendor the other day that told me that I should be at 17. 0 - 17. 5 degrees with my set up. I am currently at 15. 5. I wonder if anyone has messed with different timing settings with a hot truck on a dyno or has seat-of-the-pants experience?
1998 2500 Quad Cab, 12V, 5spd, 4x4, HD Transfer Case, 370HP Diamond B Injectors, #4 TST, 16cm2 Housing, AFC Spring Kit, BD Governor Spring Kit and other governor modifications, Walker Muffler, 285/75-16 BFG AT's, Stainless Steel Tube Steps, Reese Fifth Wheel Hitch, Leather, CD, LSD Dana 80 Rear, 60 Front, Centerforce Dual Friction Clutch, Rancho RS9000 Shocks, Rancho Steering Stabilizer, ATS Exhaust Manifold, Psychotty Air Induction, BD Exhaust Brake, Enterprise Engine Delivery Valves
Anyone have any more to add to the timing question?
1998 2500 Quad Cab, 12V, 5spd, 4x4, HD Transfer Case, 370HP Diamond B Injectors, #4 TST, 16cm2 Housing, AFC Spring Kit, BD Governor Spring Kit and other governor modifications, Walker Muffler, 285/75-16 BFG AT's, Stainless Steel Tube Steps, Reese Fifth Wheel Hitch, Leather, CD, LSD Dana 80 Rear, 60 Front, McLeod Dual Disc Clutch, Rancho RS9000 Shocks, Rancho Steering Stabilizer, ATS Exhaust Manifold, Psychotty Air Induction, BD Exhaust Brake, Enterprise Engine Delivery Valves
flat;
I have a timming tool, if you want to do it your self, and save some money, i just done mine last week, i would be willing to help you to maby save some money, it only took me like a hour to do mine. i live north of kc e-mail me if you are interested. i have been tring to get a group going but i am having a hard time finding people. well let me know.
adam
"POWERSTROKE THIS"
Adam Harman
95 auto red and white #6 tst , eagle alluminum wheels. Stright pipe, Goerend Converter, vb work, 15 degrees timming,ramsey 8000# rear mount winch. Still BOMBING
Higher timing will:
1. Lower EGT's
2. Maybe give better milage
3. Give more HP
4. Make higher cylinder temps.
Once you get too high, pistons will start to erode. I'm above the 20 degree range but I am forseeing high temp marine pistons in my future. #ad
BigYellowIron,
I thought I had responded back on this thread that I had gotten my timing advanced already but thanks for the offer. As for the timing it was advanced to 15* and I have noticed a little lower egt's with about the same fuel mileage and I also noticed that I seem to have lost some low end and was also wondering if this is normal but it does pull stonger once boost comes up and the rpm hits around 1500-1600 rpm
Paul
