Ok guys, I did a pretty standard rebuild on my pump. No major hickups. 366 spring ground the pin. All back together no extra parts.
I have the higher pressure piston lift pump, So I swaped my fuel lines to 6an braided lines and an adjustable regulator. I have the regulator at 15 psi. This is no race truck just a quick work truck.
I bled the lines for about 20 minutes. Still not getting good fuel on all injectors. Do you think I am sucking air. Or do you think I screwed the rebuild up.
