I'm in the process of designing/procuring all the parts necessary for a pusher pump install (Carter 4600). An old post stated that this pusher pump would be a blockage if it failed so my plan is to use a bypass line around the pump with a check valve inline. My dilemma is what will happen if the OEM pump fails, will it be a blockage to the pusher pump? If so, my thoughts for a remedy would be to install a bypass line around the OEM pump with a manual shutoff ball valve that can be opened to allow the pusher to bypass the OEM pump if it fails.
Anyone use this design? Any ideas/comments?
Thanks,
Bill
Thanks,
Bill
