Steve St.Laurent
Staff Alumni
Just got home last night from a much needed 10 day vacation and am catching up on threads. When I added the pusher pump to my truck I talked with both a Cummins engineer and a Dodge engineer that are responsible for our engines and both of them told me that 22 psi wouldn't be a problem with the exception that I may have a hard start problem if pressure was over 7 psi while cranking. I made mention of that in my original post on the pusher pump and have mentioned it several times since. What I do is turn the key on and wait for the pumps to shut down and then crank it and it lights right off every time. If I rush it and crank it immediately while the pumps are running then it will crank over several times before it starts.
DEZLPWR - you are probably seeing over 5 psi still. The ECM cycles power on and off rapidly to the pump to get the low pressure cycle. Most likely it cycles too fast for the relay to turn off and on.
