John, that's real interesting on those Mallory psi's. I'm curious if it ever blew the inline fuse. I have mine set up with a relay, using a 30 amp inline fuse from the battery to the relay and the 7. 5 amp (???) inline fuse by the pump. I've heard that they blow fuses if you push them past 15 psi's or so, but never tried. Mine is set at 13 psi's post filter, when warm, cold I see around 11-12 psi's, all readings at idle. My only concern with the higher psi's in regards to the Mallory is it's life expectancy. Your thoughts ????
I still have to wonder if my adjusting the Mallory dead head when the truck was off didn't help to destroy the first pump. I had that allen screw turned in quite far before I reached my desired psi's, which were only 12 psi's pre-filter then. When I adjusted the second pump, I did it with the truck running and it only took a 1/2 turn at most to see 14 pre and 13 post filter.
The one thing that I really like about the Mallory is that it is completely re-buildable, I now have a spare.
Todd, that's good info that the truck is still driveable with one pump down
Scott W.
Scott W.
