Putting a plate in a 95 auto??
New toy
Gauges are on the way!
A friend of mine has a 95 auto, and I slid the plate forward and clicked his starwheel out. Now he's wantin to put a bigger plate in it. Well I was told that b/c his pump is the 160hp pump that putting a bigger plate in without jumping up to at least a set of 215hp injectors wouldn't be a good idea. He pulls a trailor alot, and I dont wanna put a bigger plate in it b/c I dont wanna put that much strain on it if that's true. Please give me some info. Thanks
  • 2001 Cummins, 2500 4x4, Black, QC, SWB, Agate Leather, Every Option Available
  • 3:55's, Auto, 2. 5" Skyjacker Lift, 33x12. 50 BFG Mudders on 16. 5x9. 75 Weld Super Single II's
  • JVD Torque Enhancer, BIG custom Injectors, HX35 w/12cm housing, High Stall Pro Torque Convertor, Custom Performance Valve Body, Silencer Ring removed, K&N Air Filter, TC Lock-up switch, Holley "Black" Pro Series lift pump, Custom Fuel Lines, external Holley fuel regulator
  • Straigt Piped, Isspro Boost/Pyrometer Guages mounted on A-pillar
  • Dee Zee Diamond Plate Toolbox, Bed Rails, Tailgate Protector, Chrome Rocker Panels, 4" Chrome Tip
  • Westin Chrome Push Bar, Brush Guards, Drawtite Removable Gooseneck Ball
  • White Face Guages
  • Cobra 29 Sound Tracker Night Watch CB
  • Alpine 7949 Competition Head Unit, 2 10" Kicker Comp VR's in MTX Thunderform box under rear seat, Kicker ND22 Tweets, Alpine V12 amp, Kicker 460 amp.
  • More to come...
I think he needs to upgrade the transmission first. Otherwise just more noise and not much action. I still have the 160HP injectors and am waiting to see if they deteriorate and give me an excuse to get the 215s. No luck, the orginal injectors are still going strong at 163K miles.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,DTT TC/VB,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
tst 250/635 in mine,,stock injectors,,stock transmission,,,188,000 miles,,egt's a little high though while towing
94 2500 4x4 SLT,auto,187,000 miles,3:54,brilliant blue/silver,tst 250/635 set full forward,star wheel wide open,air box ported,pump turned up 20%,k&n,gauges,cat gutted,
2001. 5 3500 4x4 q-cab slt,auto,8900 miles,3:55lsd,brite silver,tst power max 3 adjustable,j-hook,3 gauges on the a-pillar,2" tuff country front leveling kit,vinyl graphics,dee zee runnin boards,both have 12k hitches&15k's in the beds,30ft fourwinds 5er,(MY RAMS) http://albums.photopoint.com/j/AlbumIndex?u=1360183&a=10142301
So far so good on my 2wd Ram. I still have the stock injectors on it. I'm fixing to put a #6 plate in my 4x4. Probably won't upgrade the injectors until I do the transmission upgrade. Your friend can probably make his transmission hold together if he will just be careful how and when he uses his new found power.
Daniel
95 2500 SLT Laramie 3. 54 automatic JVC cd out of factory infinity system, southwest grill gaurd (a favorite amongst the deer population), K&N chunked, AFC adjusted, "gutless" cat, Geno's dual EGT/boost gauge, TST #6 plate slid all the way forward, AFC housing slid all the way forward, silencer ring removed
95 2500 SLT Laramie 4x4 automatic, Geno's dual EGT/Boost gauge, straight pipe is coming next
"Only thing better than having a Cummins is having TWO Cummins"
#6 no mods yet, TC shipped yesterday. been in there for 10000 miles.
Adam
"POWERSTROKE THIS"
Adam Harman
95 auto red and white #6 tst , eagle alluminum wheels. Stright pipe, Still BOMBING
Thanks for the info guys. I know it's gonna help the truck a good bit b/c another friend has pretty much the same truck as well and he has a 250 plate in it, but the main reason for concern was the towing issue. I guess we'll have to try it out this weekend and see what it does. Thanks
Blacky,
it is a good idea to put injectors in. It's not the injectors that suffer, it's the pump. This of course eludes some people, and haunts others. It is a matter of many variables, but what is a constant is the pressure is increased by increasing the fuel load and not the injector size.
If I had to do it over again, I would do the valve body in the trans, *before* the first power upgrade. That way my trans might have lasted longer than 44k miles.
