Pyro Probe install
Does anyone have the stock sachs clutch kit part #?
electrical gremlins, wipers, alternater
I am going to drill my manifold and install a pyro probe, is there a divider in the middle of the manifold like the newer pickups, or can I put the probe right in the middle. Or where are you guys putting the probes. Is the front or rear any hotter than the other? Thanks
What is the pros and cons of installing the prob in the pipe right after the turbo? I got trucks were there installed in the manifold as well as the pipe
with the same results , ,not by me ,when i bought them , only thing i noticed so far is the prob is in the manifold i have to replace more often un like the pipe installed ones
Running the probe in the pipe will normaly give you a reading that is 300 to 400 degress cooler than before turbo temps.
When I did my Edge kit they strongly recommended installing in the manifold I know on my 04 it was a pain in the rear to find a flat spot to drill. Mine is at a slight angle into the down part right before the divider.
