Pyro readings?
Center console hinge tabs
Check Engine Light & Tach Problems
What are the noraml readings I should see on a stock truck? Right now I will see 400 to 600 around the nieghborhood and up to 700 @ 60 mph. At WOT as high as 1000. Does it sound right?:confused: The pyro is pre turbo. And this is without the EZ.
Thanks
Chris
Well, I responded to the other post, may as well respond to this one. Again, with the ETH stock, around 550-600 while cruising on a flat run at 55 MPH. At WOT, around 1200-1250 (pre-turbo, as you are) while really in it on the grades. After the EZ and elbow I found the egt's to climb faster but settle somewhat lower, around 1100 or so max.
Scott W.
Cool, another Saint owner!!!! Have any pics. , Denny, I would love to see him. Every once in a while, I take 'em for a ride in the company car, they like to pretend to be K-9, lol. Really turns some heads.
Scott W.
