My pyro has gone dead. Last year this same thing happened and the advice was to take apart the connection where the sensor ties to the gauge (is that the thermo-coupling?) and make sure it was dry and reassemble. I did that and it was fine until this spring. I guessed that the high humidity and heavy rains were causing wetness to somehow build at the connection. I took it apart, but this time the gauge still doesn't work.
Pyros work on resistance, right? And you're not supposed to mess with the length of wire going to the gauge, right? What can I check and where? I tried searching the forums, but wasn't getting anywhere. Thanks.
