Ok, i'll give that a try, Thanks, monte1/4 npt requires a 7/16 drill bit. If your not positive of the size you can double check the probe fitting by screwing your probe into a standard 1/4 pipe fitting.
Found a 1/4 tap and is bigger than the probe nipple, so now i am guessing it is the 1/8", what size of drill bit will i need for the 1/8 tap?, 5/16 ?, Thanks for your help, Monte1/4 npt requires a 7/16 drill bit. If your not positive of the size you can double check the probe fitting by screwing your probe into a standard 1/4 pipe fitting.
