Quad-boxes & mobile ham-radio operators
White smoke at light throttle
Fan Clutch wiring diagram
Axekicker
What does 'ham' radio have to do with our 5. 9's motors you ask? When I key up my radio mic, it kills my motor... . that's what! My question is for guys running the older 'Quadzilla' boxes and ham radios. Do any of you have a similar problem with your Quad-box (or any aftermarket box for that matter) and your ham (or CB) radios? My Quad 'race-box' was purchased & installed in 2005
I've tried to isolate and choke the RF that's getting inside my engine-control circuits and it appears the Quad-box is the culprit. When I key-up, the Quad LCD-readout goes haywire... . the motor stumbles and dies if I don't let off the 'key' quickly.
When I have half a day off, I'm going to pull the Quad-box... all it's wiring and the monitor, they see if the problem goes away... and I bet it will. Am I the 'Lone-Ranger' on this one or is anyone else having a similar problem... and if so... . what have you done to improve or correct the problem with your truck? (FYI: for you 'ham-sters', I'm running a Yaesu FT-450 @ 100 watts-out thru LMR-400 and an OPEK Ham-stick. The entire truck has been 'RF-bonded' and all radio circuits & cables RF-choked).
I do not believe it's your Quad, lots of folks have had similar problems with a completely stock truck. If you do a search, I'm fairly certain you will find quite a bit of info.
Have you guys thought about shielding the box and grounding it?
Here's some photo's of my efforts to-date. Some of the photo's show the braided RF-strapping that I've installed on all body panels, battery and motor. In other photo's you can see the RF-chokes I've installed on electrical wires & cables along with an RF feed-thru choke on my antenna coax. That green sheet laying on my work table is medical grade sheet lead that I've wrapped all around my Quad-box... then I wrapped the box in several layers of aluminum foil; reinstalled it in the truck and RF-choked the incoming wire loom to prevent RF-migration into/out-of the box via the electrical wiring connector. Even gamma-rays won't get through that set-up! But I still have the 'stumble/cough/die' problem when I 'key-up'.
So the answer is ... . 'Yes'. I've done 'all' that, except for your recommendation to 'ground' the box. The box is already grounded via the DC-electrical circuit ground... and I 'RF-choked' the ground cable where it enters the 'box'.
I have done the 'search' multiple times since 2005... . It's true that 'some' people have this problem... but there are a lot of 'our' Dodge 'diesel' trucks pressed into commercial service (ambulances, tow-trucks, OTR hot-shots, construction, Forestry, sanitation services public-&-private... etc... ) that have commercial radio's installed in them which typically run 100-200 watts, and those vehicles do not have this problem. (Yes... I understand that most of those trucks operate at VHF/UHF freq's and I'm primarily HF... . but the basic principles are the same regardless of frequency). I was hoping that our ranks might include a commercial radio-installer who knows the proper way to 'RF-choke' these trucks... It can be done and has been done. I just need to brush-up against someone here on the TDR, with more 'smart-cells' than I to help me with the missing 'ingredient'.
It is your Quad box. Mine did the same thing with my 55 watt Fire department Icom radio. I have to wrap the quad box in aluminum isolation tape including the wires as the wires were the key to killing the absorbation of the RF interference. I also had to direct wire the groud of my radio to the battery. All that fixed my engine dying issue when I Q'ed up the mic. It took all day to get it just right.
KF7GCQ... ..... usually monitoring 40-meters mornings & evenings and 27. 385-lsb when the 'skips' running strong.
It is your Quad box. Mine did the same thing... (edited)
Ah! Thanks for the response. I'm going to pull all my 'Quad' connections Saturday and see if that makes a difference... . If it does, I know it's the 'box'... . and then I'll hook it back up and do some more 'shielding' as you suggested, to see if I can't 'choke' it out of the Quad-box circuits. Thanks for your input! If I have success, I'll post my results.
