Quad4x4 NV4500/Christmas wish list '05
Get to drive my favorite to the hills
Long burnouts
$4395 for Quad4x4's NV4500 kit :{ :{ :{ :{ :{ :{ :{ , guess I shoulda got one a couple years ago when they were like $2600...
That's like a whole nother 1st gen!!! Wonder if Standard Trans reman's are worth the $2100? Come complete? Send your getrag back for core?
Ok off rant... What's on everybody elses wish list??
I want me a HTB2 and a new set of shocks and springs. Would like a new set of wheels and tires too, but I'm not holding my breath. :-laf
You can do the NV4500 swap for much less. Just have to be patient. It took me over a year to amass the parts to do it. I spent right at $2500 including a brand new transmission and a new clutch.
Wish list. Ok, how much room do you have. Oo. :D I have officially begun redoing the crew, so I need ALOT of parts. As for your trans delema, I just picked up a 4000 mile pull out NV5600 for $2600. They are out there, as BJ said, be patient and keep looking.
Robert
P. S. Wish list,
4 mint bucket seats
clutch set up (still havent decided)
Gear Vendors Overdrive
19. 5 Alcoa's
Motor mods for 425 hp :cool: :D
Tailgate trim panel for 93
Money to buy above :rolleyes:
Sheesh, Christmas list. This is what I want/need. ;)
Drill press
Band saw
about 5 detroit lockers
Georend Bros t/c and valve body
Some PODS
Roller cam for the 440
Port work for the 440
Roller Rockers for the 440
My wife needs
Rebuild kit for a TH400
Shift kit for above
2500 rpm stall convertor for the TH400
That would be enough stuff to get the chevy on the track, the 440 wingin' 7000rpms down the track, and the 90 setup right for wheelin in the timber.
Note, this is the short list... ... :-laf
Uhhhmm, Bill are you giving up on the Getrag? Been reading and it doesn't sound like the NV 4500's stand up much better to abuse then a good getrag... You've been working on a VE fueled hot rod, doing it your way, why not keep in the first gen mindframe and build a Getrag to take it??
Michael
I would like a working tailgate and driver side door hinges! LOL everything else is tight and dry. Ordered my 3200gs today, also picked up 4" elbows and a 6' straight piece to start on the ehaust. I was at a site the other day and saw you could buy that piece of exhaust that goes up around your crossmember and t-case in 4" Anyone recall which site this was? Or has anyone made one, i do recall its a tight fit in there probly not a mandrel bend?
____________
1993 d250 to w250, auto to nv4500, south bend, PODs, HX-35/16, open air intake, pump & timing tweaks, auto meter gauges, 5" miter cut stacks, mickey thompson classic IIs, mastercraft courser ATs 275/85/16
www.bigexhaust.com. Under diesel systems/big exhaust brand.
Yeah yeah, I should 'think' about rebuilding my getrag. I don't think a 4500, or Dana 80 would be considered abandoning the 1st gen mindframe . . too much ;) . More than likely won't go the nv4500 route, just venting :p .
Yea,
I've been seriously considering the NV4500 conversion from 518 I found a setup for 3495. 00 at High Impact. . most everything but a pedal assembly. I could recoupe some of the loot by selling my 518-HughesTC & factory HD transcooler. might have to wait till Jan or Feb though... . Might just keep my eye out for a first gen with the 4500 conversion already done?...
Well I know I'm getting a new headliner for X mas. . Does that count?
This is very much a WISH list. :-laf
4" Stans Exhaust
BHAF
PODs
Smaller Turbo Housing (haven't decided which one)
Gauges (Pyro, Boost, Trans)
New Leather Seats
Hedliner
New Radio/CD player (factory doesn't even work)
HD Rubber mat to replace carpet
BW Turnover GN Hitch
I know there is more stuff I need/want for the Cummins, but I think that would make Santa and rudolph work for their cookies and milk! :D Oo.
Eric
POD's, twins and a posi unit :D
I agree with Miller on the trannys. alot of guys sound like there having plenty of trouble with the NV4500 too. Stomp still has a getreg, thats a good enough reason for me to keep it. I think mine will need a rebuild before my christmas list comes true but The parts are pretty reasonable I thought. Bill, hows that thing run with the new turbo anyway, how much difference did it make? good luck to everybody on there x-mas lists :D
Cade
Well I doubt I will get any of these for Christmas, but here is my list...
NVG4500 (to replace the A518) and related goodies.
NP205 w/29 spline input shaft
New bench seat.
LineX over the rail bedliner.
New shocks for all four corners.
