Quadzilla Commander Control system
fuel pressure...not
Source LFS802BPE Filters, AFE 24-40044 Filters (Scotty II)
Is anyone out there using the Quadzilla Commander Control System that I see in Geno's catalogue? I would like to have some input on how this system works. If anyone has any experinece with it I would appreciate the info.
I just need to be able to monitor fuel pressure, EGT, & boost
05, 3500, dually, stock,
I have a friend with a powerstroke that has one. It works as advertised, and quality appears to be great. It's easy to use, easy to read, and doesn't take up your pillar like analog gauges.
Geno's is an EXCELLENT place to buy from.
Quadzilla are also TDR members, you'll see quad post from time to time. Nice guy.
I have had more than great luck with all of the units I have sold and installed. I think you'll be very pleased with the purchase.
BLove,
I have one on my truck(from Geno's) as well as anolog gauges. The unit is easy to install(should be even better when they get thier sensor plugs vs. the current wire taps). You will also need the CCSFP if you want to monitor fuel pressure. It also has what they call a "data loging" menu to view the max and min readings that were shown since the last time you turned on the truck.
Quadzilla is the greatest
I installed one that i got through Geno's had great support from factory about a question i had it only took about 2 hours to install and i am a novice. the only thing i would suggest is that when you hook up the 12volt power supply that you make sure the connection is tight mine was a little loose and caused some intermittent outages once i found the problem it worked great since. i really like the way it mounts using the pillar mount and looks just like it came from factory like this
06 mega cab
