I am going to install gauges. I am wanting to monitor EGT's, Boost, and Trans temp. I have always used analog gauges in the past, but after looking at the commander setup and seeing the other things that can be done, it seems to be a good deal. The cost is not much greater for the digital that is capable of doing more. This is comparing it to three analog gauges with a pillar pod.
You that are using the commander, what do you think? Would you do it again? Any complaints? Pros, Cons?
Thanks
Thanks
