Look at signature, I dissagree, my 04. 5 never did that. There is a delay in power, but that is turbo lag.But it does it on all the HPCR's. And soot wasn't an issue in 03. It may be more pronounced in the 6. 7's, but they all have tq management.
The limit on particulate emissions was the same from Jan. 1, 1994 until Dec 31, 2006. It is possible that the 305 engines polluted less than the standard, but as the NOX standards started to ramp down on Jan 1, 2004, the engines were tuned toward NOX reductions. This increased the PM emissions beyond the standards, which were then reduced with the CAT. That's why the 325 engines have the black oil.
Originially Posted by rscurtis
I guess I dont understand. What does putting a cat/dpf in the exhaust have anything to do with the engine creating excess soot/fuel built up in the oil?
We'll just have to agree to disagree. There is no comparison in the bump past the 2K RPM range I experience with my 6. 7 WHEN IN REGEN Also it didn't do that until the reflash, I know what your point is, but that is not what I'm referring to. When in regen at 1950 RPM and 2050 are night and day. Also it lost some power in the lower RPM range. Yes, I know the 5. 9 or the 6. 7 can handle a lot more power, but I don't look at it as torque management, more like D/C trying to keep a fine balance between reliability and performance. Compare it to a gasser, you can add a lot more performance to stock configuration, the imagination can be expensive, do you call it torque management or just production keeping the costs down.I just don't think you noticed it as much, its very noticable. I can't pulls hills at 1975 rpms, but can pull them at 2025. I even have a dyno sheet somewhere that shows a jump at 2,000 rpms, and the turbo is fully lit. I also hit 30 psi of boost at about 1950 rpms, and the ECM goes to full fuel mode at about 22-24 psi so the ECM fuels as hard as it will let it from about 1600 up for me.
Did you ever have a tuner on your 04. 5 that reduced tq management? If not then its harder to imagine, but drive one once and you'll know its there.
The G56 trucks have a torque management that holds up power in the lower RPM ranges, but we will soon have a tune to take care of that as well.
I can go with that explanation, the POWER is controlled, but not for torque management, but for soot control.The only CTD's that are not electronically controlled, are the 12 Valves. The 24 Valves from 98. 5 on to present day have slowly increased the POWER management through electronics. The 12 Valves are controlled through mechanical means, but they manage the power as well. You can get mechanical devises to increase their power like you can get XXX programmers to increase the power on the modern CTD. Bottom line is, every engine made has the potential for more power to be extracted from the stock form, that goes beyond proven/tested reliability.
You're getting a bit carried away with your opinion about torque management.
The earlier trucks, an '01 HO six speed for example, did not have an ECM or PCM capable of torque management as you call it and was factory rated at 505 ft. lbs.
A very large percentage of them were modified to produce 400 hp and up and as much as 700 ft. lbs. of torque and the drivetrain held up very well.
My '01 HO six speed had 275 hp RV injectors installed when it had only several thousand miles on it and still has them at 353k miles. With those injectors the engine ]produces about 275 hp on a dyno and around 550 tq.
Many owners also added electronic boxes plus many other mods. Many current TDR members are still driving highly modified 24 valve trucks with six speed NV-5600 transmissions. Many are probably producing 650 or more tq and towing heavy trailers.
I can't prove the new ISB6. 7 engines don't use torque management, Cummins won't comment. The engine probably does use it during automatic transmission shifts, but I am still doubtful of torque management at launch.
Well said, If you don't like POWER management then buy a gasser and then spend the necessary money to increase the POWER after you purchase it, Its only money. Again, the manufactures control POWER output on any given engine, even the SRT's can produce more power, if your willing to spend a small fortune, after paying more than it's worth just to get one. Again, the manufactures produce an engine engineered to meet the standards of the industry, SOOT comes to mind, and produce an engine for reliability and meet the needs of the customer.Well I dont understand what the big deal is. It can be (and probly is) any number of different things going on at once. You guys are trying to figure out whats going on inside a trucks computer that is programmed to do hundreds maybe even thousands of things every second to keep the truck running.
Seems like a pointless lost cause to try and figure it out when there is probly multiple answers to one question and nobody knows for sure.
I've got the 3:42's, in high gear rpm is about the same as my 06 auto 1800 at 65mph whcich I am happy with. My original comment about power is directed more at the trucks overall feal. I always thought a manual would feel quicker and expected the truck to move with autority when you hit the go pedal.
Hi there Hbarlow, i pm'ed you a few weeks back re the st vs slt. As you can see I went with the ST and added the goodies that I wanted, very happy with that decision as it saved me thousands. Hopefully I get used to the truck.
The combination of 3. 42 axle and 35" tires makes for the equivalent of a 2. 91 rear axle. No wonder the truck is doggy.
